Multiple Sound Files
I have been trying to get the [Play Sound File] module to play successive wav files and it is not working. I keep getting a "invalid file name" error. I have version 5.2.3010. I am entering the path as follows:
C:\Wav Files\Customer.wav, C:\Wav Files\Pin.wav
Is there a bug or am I just doing something wrong?
That should work with no problems, unless either C:\Wav Files\Customer.wav or C:\Wav Files\Pin.wav does not exit...
Try also specifying:
1.wav, 2.wav
That should results in "one two" being played...
Here is the log
162326.16  9 linedevstate 2048 0 0
162326.16  9 callstate OFFERING 65706 0 4
162326.20  9 Lev_CallerID [3083835584,CELLULARONE,0000]
162326.21  9 rv    add [DNIS]{0000}
162326.21  9 callinfo CALLEDID
162326.21  9 callinfo ORIGIN
162326.21  9 ring 0
162332.18  9 ring 2
162332.18  9 Answer the call at 10/10/2004 4:23:32 PM
162332.19  9 lineAnswer(65706) => 65689
162332.71  9 callstate CONNECTED 65706 1 0
162332.72  9 callstate CONNECTED 65706,1,0
162332.72  9 WorkingModeTAPI@Connected=
162332.72  9 WorkingModeScript@Connected=
162332.77  9 Inband detection not enabled
162332.77  9 StartLoadedVgs at 10/10/2004 4:23:32 PM
162332.77  9 AddRVns [ScriptsPath]{C:\Program Files\VoiceGuide\Scripts\}
162332.77  9 AddRVns [ScriptPath]{C:\Program Files\VoiceGuide\Scripts}
162332.77  9 rv    add [$RV_STARTTIME]{10/10/2004 4:23:32 PM}
162332.77  9 rv    add [$RV_DEVICEID]{9}
162332.78  9 rv    add [$RV_CIDNAME]{CELLULARONE}
162332.78  9 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
162332.78  9 rv    add [$RV_CIDNUMBER]{3083835584}
162332.78  9 tapi  Reply (LineEvReply) ok 65689 0
162332.79  9 callinfo MONITORMODES
162332.79  9 timer clear
162332.79  9 [Play 60] Playing
162332.80  9 [Play 60] Playing (C:\Wav\Pin.wav, C:\Wav\cust.wav)
162332.80  9 play set playid=685676
162332.92  9 PlaySoundStart err=[0 play  PlaySoundStart ResetWavOutAndContinuePlay=>32,play  pss   EnsureWaveOutIsOpenAndReady=>play  waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Wav\Pin.wav,C:\Wav\cust.wav]
162332.92  9 path {WAVERR_BADFORMAT} not found
162332.92  9 play set playid=685676
162333.02  9 timer clear
162333.02  9 RunModule PLAY end
162333.03  9 play  end old playid returned=0 (current=685676)
162333.03  9 wa(4433,68567600)
Just to elaborate on this problem, I found that VoiceGuide 5.2.3063 will report "Invalid Filename" when using the play button in Script Designer > Play, but when running the script over the phone line will work just fine. Apparently the built-in player cannot parse the multiple filenames.
Tim
